Printer says the paper is jammed in the paper output slot. when this error came up there was no paper even envolved. I hit print on my computer and the output tray pops open but something in front of it. i just moved what was in the way and then the error came up
SOURCE: ERROR: Paper Output Jam
HI i just recently 5 min ago fixed this problem.....I tried for days. Most likely something like in my case a small bobby pin fell in the back tray and went into the machine. Some people turn the machine upside down and shake it to get whatever it is out.. nothing fell out of mine when i tried this.. I had to take off the left side of the machine panel ,,,2 screwss in the back and pry down and outward there are 2 screws in the front as well under the silver corner push downward on edge.
I held a piece of paper in front of the front roller and revese fed it into the machine by turning the exposed "wheel " on the left side. You have to guide it through lift up top to see in there as the paper goes under the white rollers. At this point the paper may jam so look inside top at the white rollers about an inch from the right there is a small rectangle shaped hole in there is a black plastic part that part needs to be lifted with a paperclip so the paer can be feed under it,,,,at that point is when the paper i was reversing pushed out a bobby pin.....now mine works great again......main thing here is there mostlikley is something clogged in there,,blocking the paper.........also check you paper that gets stuck my paper kept having a bend in it where it jammed and thats where the pin was in there.
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
SOURCE: Error - Paper Output Slot
Same problem with my mp600. Turns out I had a black twisty-tie in it. Must have fallen in from the top and ran through the printer as far as it could but got stuck on the way out. I pulled it out and presto!
SOURCE: "Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
SOURCE: I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
