SOURCE: I have buffalo WHR-G54S and i cant portforward
Are you by any chance using www.portforward.com ? Because I just checked it and all of the information you gave would appear to match it. If your not the owner of this router, or say your parents or your husband/wife etc. is normally in charge of the router, ask them the username and password.
If this is not the case, I would recommend resetting the router back to factory default by pressing the small round button on your router that says "reset". Afterwards the username and password should be brought back to the default values of username: "root" password : " " .
If this did not solve your problem, please leave a comment and I will assist you further.
SOURCE: Can you portforward to host online games'? Using BUFFALO WHR-G54s
Although the specific ports may be different depending on your console )or PC) and game, the following example shows step-by-step how to enabl eport forwarding to open your NAT for game hosting, etc.
http://portforward.com/english/routers/port_forwarding/Buffalo/WHR-G54S/Echolink.htm
SOURCE: unable to locate network key
The route should have a rest button. normally on the back. Press and hold it,power up the router, and hold the rest button for five seconds after power up. The router should now rest to factory defult settings. factory password should in the manual that came with the router.
Buffalo Technology WHR-G54S Wireless Default IP, Default Username, Default Password
Reset WHR-G54S by holding RESET down while powering it on. Hold 30 seconds, then remove power
