Factory reset without disc
SOURCE: i install windows xp on toshiba satellite
A Fn key combination locks them
Try pushing Fn and F10 to unlock the function keys
SOURCE: how do i restore my toshiba satellit pro a200 back
If you have a backup, you can do that, off your hard drive. Otherwise, you will need to get a replacement disk from Toshiba.
SOURCE: i need to reset the bios password on a toshiba
There are 2 ways you can reset your bios.
1.
On the motherboard there is
a small watch battery. Remove this battery along with the power cable
from the power supply. Hold down the power button to fully discharge the
system. Wait 2-3 minutes then reinstall the battery and plug in
your system. Your reset is now complete
2. Some motherboards have a 3
pin jumper by the battery. Lets say that the jumper is on pins 2 and 3.
Remove the jumper while the machine is OFF and place onto pins 1 and 2.
Power on your machine for a minute. (Note: Your system will not POST).
Shutdown your machine and put the jumper back to pins 2 and 3. Your
This is a great troubleshooting
step for those of you having POST issues or no POSTing at all. Like
other troubleshooting steps, this will not always work but usually will
depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
SOURCE: my son's toshiba Satellite L305-S5933 keyboard has
my toshiba key is sometime locked and not to work properly.may i help please?
SOURCE: WAY TO RESET TOSHIBA SATELLITE L305-S5955 TO
Close out any software currently running on your Toshiba Satellite L305 laptop. Navigate to the laptop's "Start" menu and choose "Shut Down." Hold down the laptop's "0" key and press the power button. Keep the key held down during the boot up process until the "Toshiba Recovery Wizard" window loads on the screen. Click the check box labeled "Recovery of Factory Default Software." Choose the "Next" option. Choose the "Recover to out-of-box state" radio button. Select the "Next" button and click "Next" again. Wait for the "Press any key" prompt to appear and tap a key to restart the laptop. Use the prompts that appear on the screen to choose your region, time zone and keyboard settings. Type your new Windows user name and password in the text boxes when prompted. Click "Finish" to load the new operating system. Click on this link or copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Read more: How to Restore a Toshiba L305 ' eHow.com http://www.ehow.com/how_7292537_restore-toshiba-l305.html#ixzz15nMSp0YB
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
