Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
H
Heather Nagy Posted on Apr 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code er 1f
Technician unable to fix error code on water/ice dispenser and will not work. smell electrical odor. is this a fire risk?
GORDON'S APPLIANCE SERVICE
Level 2:
  • Expert 283 Answers
  • Posted on Apr 13, 2014
Expert
Level 2:
Answers
283
Questions
0
Helped
147295
Points
733
Check all wiring behind fascia and freezer door hinge
3 Related Answers
Anonymous
  • Posted on Oct 09, 2008
SOURCE: error code Er IF is on the display and noone from sears can tell me what it is, does anyone know?
if "er if" means = ice fan, then whats changing the board gotta do with it? shouldnt the fan be changed?
Anonymous
  • 15935 Answers
  • Posted on Sep 23, 2010
SOURCE: I have a Kenmore Elite Refrigerator, Model No.
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Anonymous
  • 3773 Answers
  • Posted on Sep 10, 2011
SOURCE: Error code is....er 1f...keeps coming
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
1helpful
I'm getting the error code 1F and it keeps coming back. The water line to the icemaker is disconnected and has been. How can i keep it from coming back?
The error code 1F on an LG refrigerator indicates a problem with the ice maker fan. The most common cause of this error code is frost or ice buildup around the fan. If you have disconnected the water line to the ice maker, then the most likely cause of the error code is frost or ice buildup. To fix the error code 1F, you will need to defrost the ice maker fan. This can be done by following these steps: Unplug the refrigerator or turn off the circuit breaker that powers the refrigerator. Remove all food and drawers from the freezer compartment. Open the freezer door and allow the ice to melt. Once the ice has melted, use a hair dryer or heat gun to melt any remaining frost or ice around the ice maker fan. Wipe away any moisture with a clean cloth. Reassemble the freezer compartment and plug in the refrigerator or turn on the circuit breaker. If the error code 1F persists after defrosting the ice maker fan, then there may be a problem with the ice maker fan motor or the control board. In this case, it is best to contact a qualified technician for assistance. Here are some tips to prevent the error code 1F from coming back: Keep the freezer door closed as much as possible to minimize air circulation. Defrost the refrigerator regularly, even if the ice maker is not in use. Clean the ice maker coils regularly to prevent frost buildup. If you live in an area with hard water, consider using a water softener to reduce the amount of minerals in the water that can contribute to frost buildup. By following these tips, you can help to prevent the error code 1F from coming back and keep your refrigerator ice maker working properly.
What does Er 1F mean on the ice maker display
LG Refrigerator Error Code Er 1F or Er IF
The ice maker fan is not working properly. Try defrosting the freezer first before trying to replace anything.
LG Ref/Frzr LFX 31925st ERROR CODE ER 1F NEED MEANING AND FIX
A F1 or 1F error code on the refrigerator's display indicates a problem with ice blower fan or ice maker motor.
search LG error 1f and u will find lots of info
Error message Er 1F
Maybe this will help. i would check fan first and see if ice has built up in fan.
https://www.youtube.com/watch?v=a4MdwuoN3jc
2helpful
Front panal displays code 1F, and pads don't function
You are probably seeing the Er IF error code that indicates a problem with the ice compartment fan.
The Er IF error code indicates that the main control board detects that the ice compartment cooling fan is not working. This will cause a lack of cooling in the ice compartment and will normally result in no ice production. This is something that a service technician will usually need to correct. If you are advanced in technical skills, you may be able to correct this problem yourself. It will require the removal of the inside back panel of the freezer compartment. This is not an easy task. I recommend that you review the procedure for this task that is shown in the image below. Make sure that you are able to safely perform the tasks described before proceeding with this repair. Unplug the refrigerator to disconnect electrical power before accessing internal components. Once you access the ice fan, you may find excessive frost in this area and on the evaporator that could be causing your cooling problem and fan problem. If you defrost this area, you may find that you do not need to replace parts. If you find no excessive frost or the Er IF error code resumes after removing any frost then you will likely need to replace the ice fan. You can order this part here.
Click here for the image.
4helpful
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
7helpful
2answers
My Kenmore Elite 79577563600 is showing Er 1F. What does that mean? I cannot adjust temp or ice or anything.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#@%
2answers
Error code Er IF is on the display and noone from sears can tell me what it is, does anyone know?
ER IF means error icing fan, the problem is with a little board that is behind the water dispenser. Change this board and you will be in business.
sgt 48
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
