When i get the settings and put the ports right i open the internet explorer and get the camera viewing right but when i close the ie and reopen it the browser cant open the ip link for the camera i changed the setting and re install the ports and ips i open the camera viewing right and when i reopen it i get the same problem again !!!
SOURCE: How to port forward th 2 wire router from web port 80 and tcp/ip port 6100..?
Hi, Here is a manual explaining how to do it... lorexstore.lorextechnology.com/ pdfs/SG19LD804-161_CLIENT_MANUAL_EN_R2.pdf -
SOURCE: cannot reset 2wire 1000hw IP
The fact that you receive an IP starting with 209.154.. could also coming from the fact that the DHCP server inside your 2wire has a problem or that your 2wire changed some setting.
I would like you to open internet explorer and put the following address:
http://gateway.2wire.net/management
If the above address doesn't work, press Start, Run, type cmd and press enter.
At the prompt type ipconfig /all and confirm that the Default Gateway has an IP address similar to 172.16.0.1 or something else; if there is no value means that there is no communication with your router and we have to verify the hardware.
If there is an IP address on your Default Gateway, try to ping it by typing ping xx.xx.xx.xx change the xx with your Default Gateway IP address.
If you are not getting any reply means that the router doesn't communicate again, if you see some reply means that you can probably access to your router by opening internet explorer and entering the following http://xx.xx.xx.xx where xx is your Default Gateway address again.
Please let me know up to where you can get some result and then we will continue from there.
SOURCE: port forwarding? 2wire 2701hg-T
access your gateway homepage by opening your internet browser and typing this on the address bar: 192.168.1.254/management. then key in your system password and click on Settings under Firewall. there's option#2 (allow individual applications), click on "Add a new-user defined application", input the data and click submit another way is to enable DMZ plus mode. that option would actually make all the ports open. use this if option#2 is not working. after making the above changes refresh your router, just unplug then replug it from the power.
SOURCE: how do i install ip cameras so that i can see them
Can I use a share IP address from my ISP to connect and view IP camera on the internet.
SOURCE: remote access DVR through dydns
the host name does not reside in DNS. Try accessing with the external public ip address
Hi Nezam Makhoul, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
