My 1991 honda civic runs fine yesturday and today it wont start please help
the car wont start? do you mean the engine wont turn over or it wont fire or run? if the car does not run but it turn over, check the basic..see if you have sparks and fuel, then check all your fuse pertaining to engine and ignition. the car need to have both thing in order for the engine to run. If you getting both sparks and fuel you engine may have jump time especially with older car with high miles, it the sign timing belt getting worn, you don't want it to break. if you don't get fire from spark plug then you may have a bad coil,distubutor,rotor or timing sensor. if you get no fuel, fuse blown, bad fuel pump relay or fuel pump it self. hope that help some ..good luck
