Epson STYLUS R230 InkJet Photo Printer Logo
A
Anonymous Posted on Apr 11, 2014
Printer is not printing, when troubleshooting it stay not spooling and that there may be another problem. I have reset the spooling and it is still not working.
1helpful
HP psc 1100/1200 all-in-one stopped printing
Press and hold the cancel button and then press the start copy button release them together.
You should print a test page. No Test page an internal printer problem is likely!
If test page is good reset the spooler \. More than one way to reset spool file. Spool file controls transfer from computer to printer. Spool file a mess then printer hangs!!!
Method 1
a. Go to Start / Control Panel / Administrative Tools / Services
b. Select "Print Spooler".
c. While Print spooler is stopped, start it by double-clicking on "Print Spooler" and then click the "Start" button.
d. Verify that the "startup type" is set to "automatic".
Method 2
Create a new txt file
Type in exactly as the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Rename txt file killspool.bat
save on desk top
Double click off of desktop file to run
Next time printer hangs you can use this file again
Hope this helps?
Troubleshoot/hpDeskJet 895Cse printers,how to cancel a print job
Print jobs are kept in a print spool on your computer. Turning off your printer only clears the printer. To clear the print spool on a Windows type computer, look for the printer icon on the task bar, lower right hand corner of the monitor. Double click on the small icon will open the list of pending print jobs. Select the one you wish to delete, then cancel the print job.
Even since we install the edimax server, the printer will just halt and we have to reset the spooler again
Setting the location of the spool folder By default the spool folder is located at systemroot\System32\Spool\Printers. However, this drive also holds the Windows system files. Because these files are frequently accessed by the operating system, performance of both Windows and the printing functions might be slowed.
If your print server serves only one or two printers with low traffic volumes, the default location of the spool folder is sufficient. However, for high-volume printing requirements, to support large numbers of printers, or to support large print jobs, you should relocate the spool folder. For best results, move the spool folder to a drive that has its own controller, which reduces printing's impact on the rest of the operating system.
For information on relocating the print server spool folder, see Change the spool folder location.
To set up a printer to print to multiple devices
  1. Open Printers and Faxes.
  2. Right-click the printer you are using, and then click Properties.
  3. On the Ports tab, select the Enable printer pooling check box.
  4. Click each port where the printers you want to pool are connected.
Notes
  • To open Printers and Faxes, click Start, and then click Printers and Faxes.
  • With printer pooling, the printers must be the same type of printer using the same printer driver.
  • The previous procedure assumes the printers you want to pool are already in the Printers and Faxes folder.
  • Check for print jobs in que,this can cause the printer to spool if a print job is in que.
Will not print! was working fine and stopped?
go to start>>control panel>>adminsitrative tools>> services
right click on printer spool and select stop.
restart the printer. restart the printer spool.
Having to reset (unplug) daily
Check the Printer spool service. If documents are getting increase in que, restart the Printer spool services. It will definatly solve your problem.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
