Check
the display for an error message. If the display reads "Clearing paper
from printer," the engine has detected a jam and is attempting to eject
the jammed pages automatically. These pages will often be blank.
Check
the display for "Performing PRINT/STOP TEST" or "Performing SERVICE
TEST." Either of these messages indicates that the printer is going
through a test procedure that may eject blank pages.
Reduce
the amount of paper in the input tray if the printer is feeding
multiple blank sheets at a time. The printer will pull extra pages
through if the input tray is overfilled.
Replace
the paper in the input tray with the correct size if needed. If the
4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
Replace
the ink cartridges if certain colors are blank on the page. Replace the
black cartridge if printing a black text document that is coming out
blank. The printer may attempt to print even if the ink level is low or
empty, but will unable to print anything on the page, causing it to
come out blank.
Remove
the sealing tape from newly installed cartridges. The tape covers the
print heads and should be removed before installing the cartridges. If
the tape is left on, it will prevent ink from getting on the pages as
they print.
Press
the "Check mark" button on the control panel to enter the printer menu.
Run a diagnostic so the printer can attempt to determine the cause of
the blank pages printing. Press the up or down arrow to select
"Diagnostics." Press the "Check mark" button. Press the "Down" arrow to
highlight "PQ Troubleshooting." Press the "Check mark" button. The
printer runs a diagnostic and returns to a ready state when done.
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
have you remove sticker from cartridges first...if paper is feeding well then that new cartridges is empty or u haven't remove cartridge stickers from cartridges
Set your print driver to "Do Nothing" on Head Close and Power Up. the next time you print will pass this information to the printer and the problem will not come back - actually the default for the driver is "Do Nothing" so it has probably been changed for some reason, you will need to change it back.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
all my cartridges are full/newly changed. my epson stylus cx5200 keeps
on feeding papers, displaying printing message but with no actual print
out i.e. blank paper comes out. please help. thanks!!
