SOURCE: "cook" on display
Please reply back with your brand and model number so we can help you.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door
switch or mount trouble can be caused by slamming the door or by
opening the door while it's cooking without hitting the Stop pad first.
There
are plastic mounts inside the microwave which hold the door switches
and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes
it's a broken tab on the switch holder, allowing the switch to rotate
just out of position. This tab
can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or
handle as you try to start it. If it works or tries to work, then it's
a door switch mount or door alignment issue.
If
you or someone you know decide to look into it, we have critical
information on safety, disassembly and door switches at our site, and
our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also
be a "mini-manual" hidden inside the unit behind the control panel or
hidden on the left side behind the grille, which is very helpful when
troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
SOURCE: Microwave still runs when door is open
Is this by any chance a combination microwave? It is is-what you are hearing/seeing is the fan running to cool it down. If it is not a combi then indeed you hav a problem-probably linked to the door catch.
SOURCE: safety function activated
This
mount (which are pretty simple problems to fix) or
occasionally a
Even though a door
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
There are
plastic mounts inside the microwave which hold the door switches and
The screws on these
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
If the switch mount is
broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can find links to helpful exploded view
diagrams and part ordering help
here. I recommend that you bookmark that
link to your favorites.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you don't find yours,
or if you want to look at it without disassembling the oven, you may be able to download it here.
If you only need a
switch, you can order a universal type here for $5 postpaid.
for $39.95 postpaid in most cases in about a week or so with a one-year
guarantee.
We're
SOURCE: door open button won't work on KitchenAid microwave model YKCMS135H
Page 3 of the exploded view here shows the door open parts 24510L and 250201 (or 23551B if your full model number is YKCMS135HSS).
What look like part numbers seem to be reference numbers.
For further help you will need to contact Kitchenaid Canada here.
We're
