you may need to manually input the ip adress or MAC of router in ds. on on your cpu, you can look up your router and its properties, record ththe type of securtiy or encryption, the pass word, mac address and ip address .
On ds, check to see if ip auto config is enabled or DHCP enabled. if after scanning and connection faills, manually configure wifi settings to mmatch those found earliear on your cpu running the router, entering the mac, ipaddress ect. also be sure you are not to far from the router and the wife switch is turned on somewhere on side of unit so the wifi arcs symbol is iluminated or lit up
First, enter your wireless lan router menu. All your actions begin here. If you do not know how to change settins of your router, dont try it. You will propably make everything worse then it was before.
Try to change the encryption used, e.g. WEP, WPA, WPA2.
If you use a mac-adress filter, make sure to put your Wii's mac-adress into the list.
Did you enter the password correctly?
Is the wifi-signal strong enough?
All these are possibilities wich can lead to the connection problem you described.
go to network setting then assist me , select default location after completing it . go to advance setting then check dns server and add the server ip adress in it save the settings check it is working.
rate if helpfull
You have to configure the WDS on the 3comm, configuring it to the MAC ADRESS of the BT router (if it is wireless), if not connect it by ethernet and set the 3comm as WDS allowing the other 3 more u want to add as acepted MAC ADRESS for access points.
do you see the router in the available networks? if so, router is perhaps MAC adress protected (that is not appearing as it is for wep under available netwoks. access your router config, usualy typing http://192.168.1.1 on a working computer connected search for reference to mac access and ad your toshiba's wifi mac to the list of allowed hardware
