The TV seems to be stuck in Zulu language and I cannot tell which phrase to click on to access the correct line on the screen menu to change it to English?
Use the manual TVs
SOURCE: Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
SOURCE: SAMSUNG LE32R73BDX/XEU TV
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
SOURCE: BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
SOURCE: Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
SOURCE: Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote
select the Reset option. Using the right arrow button at this point
will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
