Computers & Internet Logo
A
Anonymous Posted on Apr 11, 2014
Compal ft01I have a Systemax FT01 that came with Windows XP Professional. I have reason to believe the OS has become corrupted and I need to know how much RAM I have to determine if I can replace the
I have a Systemax FT01 that came with Windows XP Professional. I have reason to believe the OS has become corrupted and I need to know how much RAM I have to determine if I can replace the OS with Windows 8. Thanks
Jim Keysor
Level 2:
Sergeant:
  • Expert 331 Answers
  • Posted on Mar 27, 2017
Jim Keysor
Expert
Level 2:
Sergeant:
Answers
331
Questions
Helped
83752
Points
605
If you ran Xp you have enough memory to run 7 or maybe even 10
5 Related Answers
Anonymous
  • 85 Answers
  • Posted on Nov 21, 2007
SOURCE: Laptop 'freezes' after about half an hour of operation
Is the hard drive making a clacking noise, and/or does the mouse freeze only once or freeze and unfreeze a few times before dying completely?
Anonymous
  • Posted on Jul 13, 2008
SOURCE: Sound Drivers for Windows Xp
Audio Devicd On High Defintion Audio Bus
Anonymous
  • 2961 Answers
  • Posted on Oct 07, 2008
SOURCE: Want to reinstall windows Xp on compaq presario v 3000
if you have a windows xp disc when you start to install it it will have to format it first by default unless you ask the cd to repair windows in which case it just over writes the files and registry
cpenzes
DEKR
  • 1102 Answers
  • Posted on Jan 26, 2009
SOURCE: Acer Aspire 5735z Install XP
okay you might want to write this down make sure you have your product key #
put winxp
into cd drive then restart press F7 during restart then choose option start with cd or cd/dvd whichever you have
then press enter follow instructions YOU DO NOT want to press F6 for third party or raid let system go past that
then when asked to setup on the chosen space CLICK TO DELETE partition ( or unpartion ) then enter will ask to confirm
once all confirmed your installation will start
let me know how it goes MAKE SURE YOU READ ALL THE INSTRUCTIONS THE SYSTEM WILL GIVE
Anonymous
  • Posted on Feb 27, 2009
DEAR SIR,
I need Sound Drivers for Conexant HD Audio Smart Audio 221 Supporting OS should be Windows Xp Professional. MY laptop Model Compaq Presario c700. Kindly help me Pleaseeeeeeeeeeeee
install
EMAIL ADDRESS [email protected]
Multiple OS problem[Primary corrupt]
Windows XP Professional SP2
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
The Windows XP startup disk allows computers without a bootable CD-ROM to perform a new installation of the operating system
http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
if you have a copy of windows service pack there is a program that allows you add service pack 3 to it so you have a copy of xp sp3
http://www.nliteos.com/changelog.html
if you need more help with this post a reply
hope it helps
My window is corrupted in my PC turn of & what is collusion
'Collusion' and 'solution' are very different words. In any case, you need to give more information (complete error messages, logs seen in Administrative Tools, results of trying alternate boot (hold F8 while booting) and checking logs using safe boot, etc.) if you want to do something in particular; otherwise, I'll tell you to get a Linux LiveCD like 'WattOS R4' and boot that. Windows XP is becoming deprecated and you will want a modern OS. Decide what you want to run (e.g. Steam, MacOS X, AutoDesk tools...) and consider VMs, and consider among the OS discussed at OSNews.com and MaximumPC.com
My computer says the last attempt to restart the system from its previous location failed. Attempt to restart again? Delete restoration data and proceed to system boot menu or Continue with system...
Looks like the OS is corrupt. You may want to try doing a repair reinstall using the OS CD. What is the version of windows you are using? (XP, Vista, 7)
Operating system fail to install
My dear friend you've not mentioned what exactly the problem you are facing please be specific if you can. Basically the operating system fails to install because of the following reasons
1. OS CD Damaged / corrupted.
2. Disk Drive Corrupted.
3. Some files of OS in the CD got corrupted/damaged.
4. Your hard disk master boot record got damaged.
5. Your motherboard got damaged.
Hope i was able to solve your problem.
What are the most common problems that people encounter when using Windows xp?
XP is one of the best operating systems microsoft has developed, but I believe one of the issues is when people install programs or drivers repeatedly, it can corrupt the os
2answers
Sound driver of windows xp corrupted
You have to reinstall the audio driver since you say the driver in your OS is corrupted. That is the reason for your OS not detecting the audio device. You will have your driver;s CD with you which you would have got when you bought the laptop. If you dont have your driver;s CD, then you can download the neccessary driver in your laptop company's website.
~regards,
Jegan
Microsoft Window XP
Your problem is in the virtual basic script. That is the language that Windows has supported since Win 98 came out. It is most helpful on internet explorer. Somehow your boot file has been corrupted. There is a way to edit this in your registry through Regedit, but you need to be very familiar with the Registry before attempting that alone. I recommend finding a virus protection software package to help you debug your computer.
CH
Many problems with systemax pc -windows xp
download again and hopefully there will be a remove option in the setup program..
Top Systemax Computers & Internet Experts
Ngoro
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
