Tech in buffalo ny working on dishwasher that wont fill with water drain won't close
SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
SOURCE: BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
SOURCE: dishwasher wont fill with water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
SOURCE: water wont fill
first of all, i'm gonna guess that the water supply under the sink is turned on.
the water you hear is the left over water from a previous cycle. there is always some left in the hoses after it drains, just like your washer.
this is 1 of 2 things. either your float is stuck in the up position or your water inlet valve is malfunctioning. the float is the quick and easy fix. the float is somewhere inside your dishwasher. it tells the water to stop coming in when it reaches a certain height, just like your toilet. it could look like anything, but most likely a cone or a little hat. just grab it and try to move it up and down. it should slide freely. it was probably stuck up and your handling will have solved the problem. we hope.
if the float was ok, the inlet valve needs checked or replaced. it is under the machine and has the water supply line hooked up to it. good luck
Two things to consider....clean water or
dirty water?
Clean water usually indicates the fill valve
is not shutting off all the way and the fill valve is "weeping" water
in all the time = new fill valve time!!
Dirty water usually is not a dishwasher
problem but more of a plumbing issue. Often the sink drain that carries the
sinks water outside is not fast enough and some of this sink water is backing
up into the drain hose and filling up the dishwasher through the drain hose.
The drain from the sink to outside needs attention as this type of a problem
indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
