Hello!
I have set up my network on new DIR-625 - by cable it works fine, but I cannot connect with the router wirelessly. Computers with wi-fi cards can see the network, all the settings are OK but I keep getting "Windows cannot connect to
There may be several issues based upon your description based upon the pcs that attempt to access the router wirelessly -
what are the OS? Vista? XP?
Do the PCs have firewalls installed? How are they configured?
Are your PCs configured with different subnets or static IP addresses from the router? To explain - if your router has an ip address of 192.168.0.1; and your pc does not have a dynamic ip address (set by the router), but rather, is set for 192.168.1.2, you won't be able to connect - you'll need to modify the ip address on the pc.
On the router, how is the wireless setup? do you require MAC addressing? what is the security? WEP? WPA?
With your situation you can see the wireless network but cannot connect you have to change your DNS.
*that will depend on your operating system.
RFID or WI-FI symbol on credit cards
