did you put the tv into pairing mode so the tablet can discover it . I suspect once the tv is put into pairing mode it will reveal the pairing code needed.
You will have to pair the Bluetooth device with your phone or tablet. Find in the manual which buttons to hold to put it in pairing mode. Set Bluetooth on on phone or tablet. Look in the manual If a special pin code is required, but most of the times this is 0000. Check under Bluetooth if it is connected. Have fun.
The pairing code for this headset is indeed '0000' (four zeros).. You must put it in pairing mode, prior to trying to pair it with your phone. To do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make its bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds). By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
