Mitsubishi WD-52531 Television Logo
A
Anonymous Posted on Apr 11, 2014
Blinking red then orange light on a mitibishi
Green orange then red flashing 3 times light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
2answers
Panasonic standby light blinks Red/Orange why?
set is trying to move from standby to power supply on and not making it, No model indicated so best advice is take to some shop and get an estimate.
Pwoer shot G5 red light blinks while charging
Absolutely. It blinks orange (or red) while it is charging. It will glow steady orange when the charge reaches 90% and green when fully charged.
3helpful
Why does my gateway nv53 battery light blink while charging?
Hi, The LED light on your Gateway NV53 Blinks while charging because it was designed to do so. According to the user manual, if the battery light is:
Solid Orange: Battery is fully charged Blinking Orange: Battery is charging Blinking Red: Battery is critically low Solid Red: Battery problems, contact Gateway support immediately.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
1helpful
2answers
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
1helpful
Blinking orange light
green light mean on
orange light means standby
red light means power failure
no light means the fuse my have blown
good luck
shaun
Ride me I can help you Contact me on Live expert ttech
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
