Question about Disney Princess Toyota FJ Cruiser 12-Volt Battery-Powered Ride-On
Wont go will not go forward on low and will not go in reverse what do i need to replace
2003 trailblazer wont go in reverse .
Low on Transmission fluid or internal transmission problem.
Jul 24, 2014 | 2003 Chevrolet TrailBlazer
Atv wont shift into high gear
Is this an electric shift?? SORRY.. take it to a qualified professional!!
Sep 02, 2017 | ATVs
Low oil pressure
I tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. it wont move
forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.com
Feb 26, 2018 | 1995 Buick Regal
95 dodge neon wont go into reverse
Reverse clutch pack problem .
Mar 11, 2017 | Cars & Trucks
Automatic Transmission goes into all forward
check fluid if it is a dark color and stinks transmissions probably needs rebuilt sounds like low reverse or direct clutch is bad trna will still go into loe by using forward clutch if low reverse is bad shoul be having problems with 3rd or direct in forward if forward clutch is bad
Nov 11, 2009 | 2000 Ford Ranger SuperCab
Truck only goes in reverse
My experience would say that your 1st gear in your transmission is shot,
Aug 25, 2009 | 1983 Chevrolet Chevy
Only goes in reverse after recent charging
I would replace the high/low switch and the reverse switch.
I had the same problem of it not going forward, but I just replaced the high/low switch. It turns out 1 month later I had to replace the reverse switch.
Here is the link to the site that I found my switches on.
http://www.shopjandl.com/mepu0003.html
Hope this helps
Apr 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg perego gator wont work in forward but works in reverse
I would replace the high low switch for this peg perego gator.
The high low switch as seen here http://www.shopjandl.com/mepu0002.html will not allow it to go forward. The reverse switch will sometimes not work at all as well.
You can contact http://www.shopjandl.com/. They repair them and know how to figure out what is wrong.
I would also check the wiring on the motors. Sometimes the wiring comes loose and doesn't allow all the speeds to function properly.
hope this helps
Mar 24, 2009 | Peg Perego John Deere Gator HPX Ride on...
REVERSING PROBLEM
check the transmission fluid and make sure it isnt low.
Jul 16, 2008 | 1987 Toyota Cressida
C 6 transmission
Forward drive in the C6 requires both the forward clutch AND the low/reverse, one-way clutch, or intermedaite band to engage. Since you have reverse but no forward, the forward clutch is most likely the problem, since it is needed only for forward speeds and does not affect reverse. Sounds like a trans rebuild.
Jul 14, 2008 | 1988 Ford F 250
Disney Princess Toyota FJ Cruiser 12-Volt Battery-Powered Ride-On Logo
78 people viewed this question
Top Walt Disney Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Walt Disney Vehicle Part and Accessory Expert? Answer questions, earn points and help others
