Dell T3612
SOURCE: keep getting a message that says cpu shut down due
If you are looking at the pc from the front, take the left side cover off and ensure that the fan on the cpu is spinning when you turn the machine on. If it isn't, that needs to be replaced. If it is working, shut the pc completely down. Grasp the fan and heat sink unit and ensure that it does not move or wiggle at all. If it's loose, tighten the screws holding the fan/heatsink unit down. Try that and reply back with your findings.
Good Luck,
DP
SOURCE: My computer E machine T3612
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
