After burners have been heating for 15 minutes or so, burner caps begin rattling
SOURCE: Ingiter won't stop sparking.
You might have cracked the electrode if you were scrubbing next to it, otherwise you might try taking a little sandpaper and scuffing off any residue on the top of the igniter and seeing if that does the trick. Good Luck!
SOURCE: Continual clicking of the automatic ignitor even when burners are off
some JA models i have seen the the spark switces are poorly constructed or improper installed from the factory and beging to become a probelm after a year or so of use. this is not a gas pressure issue it just plain ole' bad spark switches
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: burner caps
Call a local independent whirlpool dealer. they can order the parts from a supplier, and most do not charge sipping as sears a.k.a. A&E will. And they will usually be less expensive too.
SOURCE: Need to know part nos. of gas burners and blackcaps, PLEC36S9ECA
try to bring the small part wen the place the burner cup(black cap) in the store wat brand u have also use other brand but bring it to put it in actual.
In order to test the surface burner on your electric range, the following steps should be taken:
An oven thermostat is a switch that opens and closes in response to the temperature
it senses. It is typically found in the control panel, where a
liquid-filled temperature-sensing bulb senses and maintains the internal
oven temperature by cycling heat on and off.
Adjusting the thermostat:
