Is there a way on the T7316E to have an external signal mute the speaker so when we have the announcer mic on, it will mute the phone speaker so if it rings it doesn't come over the air.
You can disable the ringer from all outside lines, under programming you can make the set to appear only, meaning that the lines will not ring.
The set will only flash when there is a call coming on the telephone lines.
If you call the extension directly (internal calls) the set will ring.
There is another option, if you use Feature 66 and the extension, this acts more like a intercom system, and can page between the two sets. It will beep on the receiving phone though.
yes, i can use that, however I would like to beable to trigger it automatically with a switch closure or something.
