Is it only when connected to the computer? If so there are several settings that could be causing the issue. The biggest is the refresh rate, make sure it's set to a max of 60HZ. Also make sure the resolution is not set to high. If your TV is 720p it's 1280x720, for 1080p it's 1920x1080 MAX! Also make sure the cable is tight on both ends. If all this is okay, it may be a hardware issue, but it's doubtful. Try hooking the computer to another TV.
If it's not a computer the issue is most likely either the source resolution or the cable.
Good luck
SOURCE: Black screen on HP PL4260N 42? Plasma HDTV
The problem is the "Y-SUS" board. It is inside the set on the left side with several aluminum heat sinks, under the left side brace bar. You can order this board from Union Electronics at www.ued.com .Search for part number: TNPA3243AB-PA
It lists for about 115$
SOURCE: I have sound, but No picture (HP PL4260N) plasma
Solution: buy a TV made by a TV maker, not a PC maker! eg: Sony
