Troubleshooting and maintenance message error for Init unable 34?
SOURCE: cleaning
The waistinktank is full and has to be changed. Buy a new one from a service partner. Dont clean the old one, cause the felt will be as stone afterwards and wont take up any ink! See link how to open printer: http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c See here how to do the resetcode procedure: http://www.fixya.com/support/t139675-need_reset_purge_counter_due_error_46
SOURCE: Unable to print. Error message Machine Error4F
here read this:
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001887&Sympt=How+do+I+clear+the+message+Machine+Error+4F+from+the+display%3f&Model=89&ProductGroup=5&ProductID=MFC210C
SOURCE: cleaning
unable to clean see troubleshooting and routine maintenance. unable to use it from then
unable to clean
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
SOURCE: Print Unable 34
There might be some paper left in the machine. Check the very edges espacially the left side (seeing from the front).
Another reason could be that the encoder strip isn t in right position or is stained from ink.
Anyway try the first solution first.
If you stll have trouble try to open the printer:
http://www.fixya.com/support/t211210-brother_mfc845cw
and have a close look to the encoder strip + disc (and look out for some paper in the edges... ;-))
