Touchpad beeps and then stops workin
SOURCE: DEll Latitude D600
The back lighting for the LCD panel has gone out. The picture is there, you just can't see it without the backlighting. So, it could be the Inverter that supplies power to the back lights or it could be the CCFT lamps that burned out. In either case your local computer repair shop should be able to fix it. If it is still under warranty take it back to where you bought it and they should have it repaired under warranty.
SOURCE: Bios continous beep, repeated ////, intermittent touchpad issue
The beeping when powering on is from the keyboard buffer being filled up by a stuck key. Same thing in windows. Best bet is to just replace it as it is pretty cheap.
Here is a link for one for $25
Easy to swap out also , here is a step by step
