SOURCE: My Compaq CQ50-110 will not boot-up. The lights
Look at the screen at a shallow angle and look for any 'ghosts;' images that you might expect to see during boot or after.
If you can discern anything, then it could be a failed back-light (fluorescent) or the inverter for it which is customarily on a single small board that is obviously connected to the display/cover half.
This is potentially user replaceable with care and a few small tools.
When you plug the AC adapter the power LED and the battery charge LED light up. When you press on the power button the laptop powers up but will not start. There is no video on LCD or external monitor.If the power LED lights up it indicates that the laptop is getting power from the AC adapter. Most likely there is nothing wrong with the adapter but just in case test it with a voltmeter to make sure the output voltage is correct.
When you press on the power button, the laptop makes a series or short and long beeps and will not start up. There is no video on the screen.In this situation test the memory module as I described in the situation2. Try installing a known good memory module. Most likely you are getting a beep error because of a faulty memory.
You start the laptop. It sounds like the laptop is booting normally (hard drive LED is flashing) but there is no video on the screenIn this situation test the laptop with an external monitor. If the external screen works fine but there is no video on the laptop LCD, most likely there is a problem inside the laptop display assembly. Go to my previous post witch covers laptop video problems in more details.
You start the laptop and it starts making repetitive clicking noise or grinding noise.Most likely you hear this noise because of a faulty hard drive. You can remove the hard drive and start the laptop without it. If the noise is gone, the hard drive is your problem. Replace it.
The laptop boots into Windows ans works for a while, but after that it shuts down by itself without any reason or warning. You restart the laptop but the same problem appears againMost likely it's a heat related issue. Listen for the cooling fan, make sure it works.
Start with the headset powered on. Press and hold down
the call control button while also rotating the multi function dial
upward (away from the light) until the indicator light on the headset
starts flashing red then green. When prompted for passkey, enter
0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter
(discontinued): Turn the headset on and the adapter off. On the headset
push in and hold the mute/volume dial until the indicator light begins
to flash. On the adapter press and hold the blue power button for 10
seconds. The light on the adapter will flash once after 3 seconds-
continue to hold the power button for another-7 seconds until the
light flashes red. If the pairing is successful, the headset will
sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued):
If you remove the battery cover from the headset and then remove the
battery itself. On the Green PC board itself there will be a letter
followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
