Oil pressure indicator light comes on
Hey Joe,
Are you sure it's the hydraulic oil low pressure or is it the engine oil low pressure light? Check the engine oil for being low, over full, filter change, right type of oil, leaks, air filter, spark plug, clean air intake, battery getting a good charge, if that stuff is ok, then find your oil pressure switch and change that out.
But it if it is the hydraulic oil light, check for leaks, that is a high pressure system so don't put your hand by hydraulic leaks use cardboard or something to check for leaks, a pin hole leak can cause severe damage to your skin from a high pressure injection from fluid.
Let me know if this helps and we can go from here
