Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hitachi LCD projection power,temp,and bulb lights flashing
I was watching my Hitachi LCD projection TV model 55SSX24K when the picture went out and made a loud snap noise....Now when I try to turn it on the power,temp,and bulb lights flash on the front and I get no picture..The TV has done this before but has come back on after leaving it off for a bit but it seems that is not an option anymore...I hope someone can help...Thanks
6ya staff
SOURCE:
Anonymous
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
Anonymous
  • 579 Answers
SOURCE: Hitachi Rear Projection LCD TV Lamp
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Posted on Dec 31, 2007
MICHAEL MULLINS
  • 927 Answers
SOURCE: Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Posted on Sep 09, 2008
Anonymous
SOURCE: chirping noise and flashing front power light.
I had the same problem with my 46" Hitachi TV. We left it unpluged for a couple of days (literature says at least 4 hours) Pluged it back in, held in on the AVX and power button at the same time, this puts it into self diagnostic mode. Error codes should appear on the TV screen, then it should instruct you to hit any key to continue. Press the AVX button and it should put your TV back to normal. I suggest however, that you download the specific manual off the internet for your TV. I got my manual from an electronic forum site (http://www.eserviceinfo.com). My TV model is Hitachi 46EX3B. Hope this helps.
Posted on Dec 05, 2008
Anonymous
  • 51 Answers
SOURCE: Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Posted on Dec 08, 2008
Hitachi model number 50V720 does not show picture or sound when turned on. The Temp light and the lamp light flash red on and off. What's the problem?
Check the tv fan it is running?No than the fan require replacing.Yes,than the tv projection lamp life are ending require replacing.
Apr 14, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi projection tv quit
Pls check that model number........the problem description does not match that of a 1999 crt proj tv.........I believe yours is a newer lcd projection around 4 or 5 yr old?? Lamp light flashing on any brand is indicative of the lamp not lighting . The lamp is the most likely cause,but the ballast board can cause this as well..................you should see an access door refer to owner book of the correct model and you can replace yourself...........it may cost around $200 and avaiolable at encompass parts .com Hitach distributor
Jun 06, 2010 | Hitachi 50UX57B 50" Rear Projection...
Hi I have a hitachi LCD projection TV my lanp and
yes you need a lamp about as sure as anyone can be without looking take lamp out see if its brke inside or has any whit smoke spots in it
Feb 06, 2010 | Hitachi 50VF820 Projection TV
No picture and flashing lights on front
Check the bulb first. also check and clean cable card fan.
Apr 24, 2009 | Televison & Video
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a hitachi 62" LCD tv.when you turn the tv on,the power light flashes for a few seconds then the temp and lamp lights flash.The tv does not give any sound or picture.
When is the last time you changed the lamp? They only last 1-2 years, depending on hours used. If not then power supply capacitors would be next. Have it checked. Or buy a lamp in change it.
Dec 02, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Good Day;
Try this:
Jun 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
238 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
