Twisting cables during operation
SOURCE: packard bel slimview 517, twisted vga cable
yes if you can solder then cut the cable and solder the 15 pin vga connecter first test the continuty between the connecter and opposite end write it on paper then according to that solder all wires but better to buy new cable for long time
SOURCE: GRIP SHIFTERS WILL NOT TWIST WHILE TRYING TO SHIFT
This is likely because either a) the cable leading from the shifter to the part you are pulling is seized or b) the shifter itself is seized or c) both are seized. You would have to undo the cable from the rear deraileur, pull the inside cable out from the casing from top to bottom. Check it and see if it is rusted or full of crud. Give it a cleaning and spray some light lube down the outer (black) cables, then reinsert the cable. While the cable is undone, it wouldn't hurt to see if you can twist the grip shifters. If they are still tight, then get some lube in the grip shift. Also make sure the rubber grips are not too tight against the shifter. Hope that helps...
SOURCE: i need to replace the window cable in my passat
get a complete regulator from vw or check fcp groton .com i am a vw tech you will be there forever if you try the cable you will never get it wound around regulator leaving you with a window that doesnt work
SOURCE: changing a cable on a sram twist shifter
You should be able to push the cable back on its self, as long as the shifter is set in the relaxed position. Then it will be a case of threading the new cable through the shifter housing.
SOURCE: I cant seem to put a new cable into my sram x0
http://www.parktool.com/blog/repair-help/shift-levers-shifters
http://www.sram.com/_media/pdf/sram/dealers/XX-Technical-Manual.pdf
Google this... "Sram X.0 cable change" = many videos
