I have DVD slide shows using the Photodex ProShow program. My monitor goes into sleep time mode after about 12-14 minutes of viewing the a show on my computer with my new motherboard and Win 7 Prof. I can't find anything in the F2A88X-D3H manual about sleep time mode adjustment. I never experienced the problem on my previous ASUS motherboard and Win XP. I am using the Gigabyte graphics on the motherboard, but I am considering installing my old PCI graphics card that I used with ASUS to see if it fixes the problem. Dell tech support claims it is not the monitor problem, but I don't know.
SOURCE: Gigabyte GA-8VM800M 478 - On-board VGA as well as ASUS N6200 vid card
this can support two monitors. but it means one through the dvi output and one through the analog and have the desktop spread over two screens..If you need help locating these ports then ask me..
SOURCE: Gigabyte GA-945GM-S2
Hi FRND,
check this link for the drivers which you want....
http://asia.giga-byte.com/FileList/Driver/motherboard_driver_lan_realtek_8111.exe
Enjoy...
Regds,
DRSS...
SOURCE: Gigabyte Nvidia 7300 GeForce PCI Express
I would look at two things first would be the video card, if it's overheating because of fan failure, that can cause crazy things like this. I would see if you can tell if the fan is working while the system is running. I would also remove the video card and clean it well with some canned air. I would also consider your power supply, make sure you have enough watts for that video card, I would clean it carefully with the air as well. My system started shutting down like that the other week, I checked my temps on my 8800 it was idling at 90 c, turns out my fan had crawled to a slow. I have now sent the card in for RMA as it's only 5 months old.
I hope this helps,
THanks for using FIxYa,
Eric
SOURCE: PCI Video wont work with Gigabyte GA-K8VM800M motherboard
hey try the removing cards.....
window 7 may took up it best when no such changes are around..
! Gb or 2 RAm is enough to get run your Win 7
and sound card is noot required untill you have 4 or more speakers
