SOURCE: Caller ID not working
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
SOURCE: Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
SOURCE: my caller id is not showing name or number of the
Since CID display to the phone comes from the Panasonic phone SYSTEM, you might try looking inside the cabinet to see if it has a caller ID card. The part ends in 93.
It also requires some programming. If you post your model number, I might have a CID card if yours is missing.
Carl
SOURCE: I just received KX-T7730 phone with an LCD screen
The one who can show the caller ID when someone call is the caller only. He/she can set to hide his/her number ID in their phone so we can't see it. We can't force to see this caller ID, but if this calls disturbed you, you can install call blocker and only allow certain incoming call to be recieved.
Hope his help and rate please.
