Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
Wiring a 220v single phase motor and capacitor
I bought an ao smith motor to replace a condensor fan motor
the old motor had 3 wires
black white and
the new motor has 4 wires
black ,white,brown , brown with white strip
black and white are line wires
how would you wire the capacitor.
220v single phase
thank you
  • 999 Answers
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Posted on Jun 17, 2009
I have an A.O Smith SE2F01 115/220v Type C electric motor, it has 4 wires: White/Black/Blue/Red, I want to know which is which? And Does it need a capasitor?
Wiring diagram appears on side of unit.
With wire colors.
Capacitor: each electric motor has a run-winding and a start-winding with capacitor.
Both windings receive power.
The start-winding gets a surge of power from the capacitor > and this starts the motor.
The run-winding brings motor up to full speed.
Copy following link for motor resources:
http://waterheatertimer.org/Color-codewire.html#motor
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 19, 2013 | AO Smith Pool & Spa
I am replacing my old a/c fan motor with a new one. The old motor is an A.O Smith B13400-251 and has black, brown, and a purple wire and was connected to a dual capacitor. The new motor is an A.O Smith...
For one, thank you for posting all the info, it really helps! On your new motor, the white has became your purple, black is black, and your brown/brown and white wires go to each side of the new capacitor, there should only be 2 terminals. You can leave the "Fan" terminal blank on the old capacitor now. Just be sure to attach the new capacitor somewhere secure, they are smaller, but can be a pain. So just to recap:
Black is still black.
White is what purple used to be (Com)
Brown on 1 side of new capacitor
Brown/White on opposite side of new capacitor.
Hope this helps get you to cooler days!
Jun 29, 2012 | Heating & Cooling
My pool originally had a 2 speed AO Smith pump motor. Several years back it was replaced with an AO Smith single speed motor. I am replacing that motor with a new AO Smith single speed Centurion Switchless...
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
May 23, 2011 | AO Smith 2 hp 3450rpm 56C Frame 230 Volts...
I want to reverse rotation on my A.O. Smith 120/230 volt single phase 1.5 HP motor. Catalog number B762
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
Oct 07, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I look at the A.O. Smith Motor Master University manual and my question concerns the diagram on page 50, Single Phase Motor. In need to operate my motor with 115V and my understanding of the diagram is...
That is correct...if you have done that and still have problems post a comment that includes a description of what is happening and the motor model and serial number for further assistance.
John
Aug 25, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Unsure of capacitor terminations for ao smith condensing fan moto
Does the motor data plate say anything about the motor. You can hook up a motor like yours with 3 wires. First use an ohmmeter and check the resistance between the brown/white wire to the black then the yellow wire. The resistance between brown/white and one of the others should be pretty much 0 ohms. If not check between the brown wire and the black and the yellow. Which ever wire has 0 ohms with the brown/white wire is the common leg. You can put a wire nut on the brown/white, it will not be used. Next the brown should be for the start winding and the other wire left over will be the run winding. Then connect the common to L2. L1 will go to the run winding and one side of the capacitor and brown will go to the other side of the capacitor. I hope this isn't too confusing. Let me know if I need to explain it better.
Jun 09, 2010 | Heating & Cooling
AO smith compressor motor missing toggle for duel voltage
Most motors will have a wiring diagram on them with numbers not colors, and show the wiring configurations for both voltages. If you do not have this then you may want to contact a motor shop and see if they can get it wired for you.
Nov 25, 2009 | AO Smith Air Tools & Compressors
I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the...
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Sep 07, 2009 | Heating & Cooling
Just replaced a rheem oem 1/6 hp motor 3 wires with a 1/3 hp 5 wire. Need help with wiring diagram. A.O. Smith 1/3 hp to capacitor
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Jul 07, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
4,009 people viewed this question
Top AO Smith Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
