Fuser error
SOURCE: error code e002 on canon copier np6050
Also this code needs to be cleared in service mode. Despite what the display says, turning it off and on will not reset it. To enter service mode insert a straightened paper clip into the small hole in the front cover, near the meters, a "$" sign will appear on the display. Press * 4 * in order. Press ">>" to select "error" then press "OK" then power cycle.
(I cant remember on that model but you may need to defeat the interlock on the front door in order to enter service mode.)
SOURCE: error code E002 cannon 6612 photocopier
this is a canon generic error code that points that the fixing/fusing heaters or sensor has a problem try to swtch off & on the unit, check the ac power supply maybe its not stable, if the problem persist.you have to call your service provider regarding this.
SOURCE: error code display 00007 in
as you probably now, the E007 is error for fixing film rotation. The rotation is checked over sensor above the film's "white" dot.
So are You sure that sensor works, is there any left overs of old film on sensor, reconnect all connectors related to the film sensor, is the "white" spot dirty or damadged, are you sure that fixing film is rotateing properly??????????
Hope that something of this will help you to find solution....
SOURCE: MI COPIADORA CANON IR 3570 ME MARCA ERROR E002 ME
tengo una fotocopiadora canon ir 3570 y le cambie el cilindro y la cuchilla y ahora no me copia la imagen sale la hoja en blanco
