It's a lens problem - the lens sometimes gets debris in between and does not extend out enough to take clear pictures or the lens is crooked from impact or damage. As for the touch screen and not being able to read the menu on your screen, that's also damage. Don't think factory settings will fix this problem. Did you try troubleshooting on google for your camera - maybe they have some fix it suggestions.
Please remove the Battery from the Camera then reinsert it after two minutes. Make sure that the Battery is fully charged. if menu options are accessible on the Camera then reset it to the original factory settings. Please follow the steps that are mentioned below to reset the Camera to the original factory settings:
(i) Please turn ON the Camera. (ii) Then use the control button on the Camera to the select the Setup (setting) option. (iii) Next, select the Setup1 option then "initialize".
Performing the above mentioned steps will reset the Camera to the original factory settings. If the issue persists then service will be required.
Please remove the Battery from the Camera then reinsert it after three minutes. Please make sure that the Battery is fully charged. If menu options are accessible then reset the Camera to the original factory settings. Please follow the steps that are mentioned below to reset the Camera to the original factory settings. (i) Turn ON the Camera. (ii) Press the Menu button on the Camera to display the menu options. (iii) Then use the control button on the Camera to the select the Setup option. (iv) Next, select the Setup 1 option then "Initialize".
Performing the above steps will reset the Camera to the original factory settings. If the issue persists even after resetting the Camera to the original factory settings then service will be required.
If you're trying to change the Language settings in the DSCT77 Camera. First, please touch the HOME on the LCD screen of the Camera. Then, select the SETTINGS in the HOME menu. Then, select the LANGUAGE SETTINGS under the SETTINGS.
Down load the ueser guide and go through Page no 53 for getting the tips regarding resetting your camera to factory settings. to down load the user guide click here. User Guide goodluck If my solution proves useful please rank me. Regards Arjun
Reset in the menu ... RESET ALL or something like that will return the setting back to factory. You could also look at your settings in the menu and check the white settings for the picture taking modes.
