The drum has come to the end of its life. You should replace the drum assembly and reset the drum counter. Here is the procedure:
power off and open front door
hold down the continue button as you power on printer leaving front door open
when error light comes on release continue and close front door.
toner low, load paper, ready, and continue will all be lit.
press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change
when just toner low is lit, press and hold continue button until lights cycle up and down in sequence.
release continue.. toner low will be lit again
turn printer off, wait 10 secs or so and then back on
press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
