Minolta bizhub 250 Black and White Copier Logo
w
wajid Posted on Apr 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Minolta Di 5520 code Solution C-13f5
Minolta Di 5520 solution code C-13f5
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Minolta Master 1,449 Answers
  • Posted on Jul 19, 2014
Minolta Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614562
Points
3628
Yes there are 2 soft switches...... left side is for trouble reset.
Remove fuser unit from copier
Reset code co05XX
The copier needs to give you a scree with wait for warm up; if not some thing else it's going on
If you get the wait for warm up ...eventually you'll get a C05XX code
Reset and test it with the fuser unit in.
Troubleshoot fuser unit in case you get another C05XX
Tom
3 Related Answers
Anonymous
  • 10515 Answers
  • Posted on Mar 25, 2009
SOURCE: MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
firecontrol7
Norman Weimar
  • 7035 Answers
  • Posted on Jul 19, 2009
SOURCE: I have a trouble code (cobao) with a minolta di
Elevation drive motor failure. was there or Is there anything under the trays of the finisher (where the copies come out?) look over the exit trays make sure ther is no damage or binding. Open close finiher door turn power off then on.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Adorjani Laszlo
  • 1316 Answers
  • Posted on Jan 23, 2012
SOURCE: minolta dialta Di 470 donne code c 0210 puis
C210,transfer/separation corona malfunction.Change or clean the corona wire and the corona holders(white Assembly).
C-13f5 Code
The code is for the print head which houses the LASER and poloygon motor which allows the LASER to write the image across the drum. Order a new one. Have technician check the electrical connections to the mother board
Replace the print head, the print head houses the LASER for the machine
C-13f5 Code release
Print Head LASER section is bad Power off then On if it comes back look to see if you can get a LAASER Print head for your machine
Sir/Mam either the code is wrong or the model is wrong. The code is for a Minolta or some konicaminolta machines the model you list do you mean Di5510 which is a Konica machine that use Konica codes like SC35-03. Also the machine problem is listed under Bizhub 250 which I could not fine the code for either.
C-13f5 code
Sir is this a Di450 or Di 550 Model? Then open up the front door and close it.if the code goes away then you are OK if it comes back your LASER print Heard or Printed Circuit Board PWB-B needs replacing. Have a Konicaminolta tech review the TB 3106, 3426, and or 3182.
Error code 13f5
please re check the code could not find in the service manual
13f5 code error minolta 500
No such number code for a Bizhub 500
2helpful
Error code sc23.03
Minolta Di 750 error code SC-23-01 i want solutions this code.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
