SOURCE: sd memory card cannot be used
This happenes when you remove the card while read/write process is still going on. Try some professional service who will retive the data for you from the mem card. Hope this helps.
SOURCE: Copy camera images to memory card through camera
In the camera setup menu there should be a backup option that allows you to copy the images from the internal memory on to the xD picture card.
SOURCE: unable to see pictures on my sony dsc t70 memory card
Try connecting MS directly to the PC (Via an adapter, if necessary)
SOURCE: will not download pictures from camera to computer
I have the same camera. The little red light flashing is normal. It should flash for about a second and then go out. I believe the camera is reading the SD card during this time. If you turn on the camera with no SD card present this light should not flash. It sounds like you’re having problems transferring pictures from your camera to the computer. I'm guessing you’re using the USB cable that came with the camera to connect to the computer. I don't have an exact fix for this problem; it could be a defective cable or connector. However, I do have an alternative way for you to download your photos that I believe will work even better for you. Buy one of those mini SD card readers with the USB port adapters. The one I have is made by SanDisk and is called the MicroMate. Here's a link so you can see what it looks like. http://www.sandisk.com/Products/Item(2018)-SDDR-113-A11-MicroMate_for_SDHC.aspx When you want to download your photos just unplug the SD card from your camera, insert it into one end of the SD card reader, and plug the other end into a USB port. The computer recognizes it as a flash drive. Then you can just copy from one drive to another. I find it to be much faster then using the USB cable to download photos. I hope this helps you out.
