Had Netflix for 3 yrs. loaded on 2 Sony DVD players fine. now on LG player code nw-4-8 problem comes up and Netflix won't load.
SOURCE: ps2 dvd player
If you want to code free parental control then here is the solution when you are asked to put the code press select, then insert "7444" and your code will be deleted and you will be asked to put new code so put a new code, if you wanna completely remove the code, so during the film press select and go to setup and then parental control and select to turn off the parental control
SOURCE: Little Leaps DVD code
Little Leaps quick setup codes:
http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=1449&p_created=1153327777&p_sid=jy6ltQ*i&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0yODgsMjg4JnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ**&p_li=&p_topview=1
If your manufacturer is not listed, try the additional manual setup codes:
http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=1491&p_created=1157747037&p_sid=jy6ltQ*i&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0yODgsMjg4JnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ**&p_li=&p_topview=1
SOURCE: making connection between WII and internet and Netflix
Sounds like a netflix issue.Contact them with any information you have from them.Here is the link.
http://www.netflix.com/HowItWorks
SOURCE: Netflix instant streaming videos will
It sounds like you have an active network connection, but test the network just in case. I am not in front of a PS3, so this is from memory. Go to Network Settings, and within that option, there should be one to test the network. Make sure you have a strong signal if you are going through wireless.
The other issue might be the saved Netlfix settings. Erase the Netflix settings file (this will erase your login and password) and try re-logging in. Again, I am not in front of my PS3, so I can't tell you for sure where this file is, but I think it is under the video section, but it is not the icon that loads up the Netflix app.
Good luck.
SOURCE: When i click on the
This is probably an error within the Netflix file on the Xbox. Try to delete and reinstall Netflix by going to the memory and hard drive.
