Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model Logo
A
Anonymous Posted on Apr 09, 2014
Turn key on will not start with new battery power to starter moter is good
RPM Small Engine Repair LLC
Level 2:
New Friend:
  • Expert 84 Answers
  • Posted on Nov 27, 2014
Expert
Level 2:
New Friend:
Answers
84
Questions
Helped
50916
Points
192
If you are saying that you have power to the starter when you turn the key then the starter is bad. You can try lightly taping the outside of the starter case with a small ball peen hammer which can sometimes jiggle the brushes inside the starter enough that it will work again for a short time.
Spencer Frasher
Level 2:
Habit-Forming:
New Friend:
  • Expert 85 Answers
  • Posted on Nov 26, 2014
Spencer Frasher
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
85
Questions
0
Helped
45024
Points
223
Are you pushing in the clutch? If yes, then it might be the clutch switch. Most mowers need the clutch in to start. I have wasted many hours by not knowing that.
4 Related Answers
Anonymous
  • 235 Answers
  • Posted on Apr 12, 2010
SOURCE: Replaced starter and sylenoid - but engine won't always turn
sounds like the bendix spring is bad on the starter (it's the spring that returns the gear to it not moving state)...good luck
Anonymous
  • 1627 Answers
  • Posted on May 12, 2010
Sounds to me like you need to replace the starter solenoid switch,follow the cable back from the starter post and it lead you to the solenoid.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Aug 23, 2011
SOURCE: My tractor will not start. I put a new starter,
Try connecting a jumper cable to the battery. You can use the battery in an automobile to jump the mower battery. If the jumper cable causes the engine to start normally, replace the battery.
The best way to test a battery is with a volt meter. A good, fully charged battery will measure 12.6 volts dc across the positive and negative terminals. If you turn the ignition key to the start position with the meter connected to the battery terminals, the voltage should not drop below 12 volts dc. Post back your results.
Anonymous
  • 6468 Answers
  • Posted on May 21, 2012
SOURCE: riding mower wont start
check the safety switch on the clutch pedal
Why doesn't my engine turn overwhen i turn the switch and try to start it?
Is there a red light flashing on top of the dash when you try to start the vehicle ? PATS - passive anti- theft system will not let the starter engage .No - crank - no start
I have a 2002 mercury mountaineer that wont turn over at all the battery is good and there's a clicking noise coming from the relay box what would that be
The clicking noise will be relays. Possibly a starter relay and thats normal. Sounds as if the starter moter may be the culprit. You have to check for start power at the starter solenoid while cranking before any further daignostics can be done. Sometimes tapping on the starter motor while holding the key in the crank position will start the vehicle. If so the stater motor is defective
I have grand am gt 2002 most time it starts.replace starter and new battrie. when turn the keyno power to moter I have to turn the keys on and off couple time and then it starts up any ideas on whats
Could be issue with ignition switch or security system? If the starter motor won't crank, check voltage circuits at the starter. Usually two voltage circuits, one is battery voltage, hot all the time. The other voltage comes from crank position of ignition switch. That circuit could be routed through the neutral switch or clutch switch, depending on your tranny.
Any testing at starter make sure tranny is in park or neutral and the parking brake is set.
Rover 75 on51 plate battery ok but starter moter juut clicks when i turn the key
Secret code yet again this plate lark,right two possibilities here either battery is no good with no reserve amperage or the starter motor has failed ,try charging the battery and then a jump start as well with proper leads not them things with a thick insulation and three strands of wire inside .
2answers
Why won't my 2001 pontiac bonneville wont start? All it does when i turn the key is click twice
Try checking your ignition fuse. Check your battery and make sure it is good. Check your wires and terminals and make sure they are cleaned and tight. If you do have interior lights, it may be the starter or startr solenoid.
In cold weather car cranks, but it does not have enough power or fuel to get it started. Have new battery. Have had to use starter fluid as well as a jump to get it started in this cold weather. What could...
a worn out starter could do it if the bushing in it are worn it would pull to much power from the battery and would not turn the moter over fast enough to pump enough gas to start the car if its carberated then it has a manual fuel pump the fuel pump wont pump enough gas if the moter is not turning over fast enough i would either rebuild the starter or replace it.
1helpful
I was riding the tractor mowing shut it off to get lunch returned 1 hr later would not start. I bought a new battery and had the starter checked all good still wont start. I get a click when i turn the key...
The starter solenoid sounds to be bad. Follow the + cable from the starter and it will lead to the solenoid. This is usually about $10. The battery produces power to the solenoid which then produces power to kick the starter over. The clicking is the contacts in the solenoid you are hearing.
My 99 chevy truck...4x4 just started giving me start troubles...everything works but starting the thing...some one told me that the computer isn't reading my key code??? the truck was crusing along until...
if the key turns lights on the dash. u can jumper the starter thru the starter relay in the fuse box under the hood. 4 wires, one hot all time jumper to starter wire thru relay wires at fuse box
It clicks will not start
My Craftsman B&S used to do this a lot. Sears told me it was the battery and that the moter takes every bit of the batter to start the motor. Try charging the battery or using a new, larger battery. The clicking is just from the starter not getting enough power to turn over and is not causing any problems. Good Luck.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
