Video Game Consoles & Games Logo
A
Anonymous Posted on Apr 08, 2014
Ps2 scph 10000 blank - Sony Video Game Consoles & Games
2 Related Answers
Anonymous
  • 52 Answers
  • Posted on May 17, 2010
SOURCE: passcode for ps2 scph-30001, i forgot mine and i
keep guessing. Nobody knows it but you. And you forgot it.
Anonymous
  • 84 Answers
  • Posted on Jul 17, 2010
SOURCE: does sony pDoes sony ps2 model scph-9004 has
PS2s do not have inbuilt memory, inbuilt memory is only available for the PS3.
1helpful
Does sony pDoes sony ps2 model scph-9004 has
1helpful
Passcode for ps2 scph-30001, i forgot mine and i
I have the PS2 model # SCPH-70012. I have taken
download? you mean play, sounds like your drive is dead
3helpful
Which multitap do I buy?
There were two versions of the multi-tap made; one for the original fat PS2 and a smaller version made for the slim. The two versions are incompatible with the other PS2. If you have the original multi-tap connected to the slim, it should throw out the 'controller disconnected' message when you boot up. The slim version of the multi-tap should have a sticker on the bottom saying 'only works with models SCPH-70000, SCPH-75001, SCPH-75002'.
Other than the sports games, I don't recall any titles that allow more than two players anyway.
1helpful
2answers
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
4helpful
Pcb no GH-006 mod chip diagram
The Modbo v4.0 is compatible with v5 to v16 and it is also compatible with the newly released SCPH-7700x & 7900x consoles. However for your SCPH-30004 I'd use a PS2 Duo 3 Gold. http://www.duomodchip.com/english/install.htm
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
