The dryer cuts off after less then 5 minutes of running then 5 minutes later it comes back on by it self
Since no model number was given, check to see if you have a setting commonly noted as "wrinkle guard", "wrinkle shield", "press care" or something to that affect. Those settings will run the dryer for as much as 90 min after a completed drying cycle to prevent wrinkles in clothing, allowing you time to remove the cloths after a dry cycle if you are busy. Pleazer Appliance...
SOURCE: Kenmore dryer 90 series
I’m so sorry my pc crashed on me..... Power Supply went out and I just got a new one put in.....I hope you got your answers......If not please let me know so I can help
cbinny1
SOURCE: Kenmore Series 70 Dryer cuts off after a few minutes
The bearings in the motor have probably worn out. Disconnect the motor and take it out of the dryer. See if it turns roughly or not at all by hand. Also try and move the post left to right and up and down and see if there is play in it. It should move very little if at all in those directions and should spin freely if it's good.
SOURCE: Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
SOURCE: electric kenmore 90 series working but no heat?
Most likely that is the heat element. Some dryers have the element in the front but most of the time yours can be accessed from the rear.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
