How do I put the glass door back on the oven door on a C970656912
SOURCE: Can't put door back
This may help:
http://www.whirlpool.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203196278.pdf?PIPELINE_SESSION_ID=62e5768ec0a8503448ca0e04446c0ca5
SOURCE: Very Old Whirlpool "Wall of Fire" Gas OVen
what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
SOURCE: Can't put door glass back in Whirlpool RF396LXE2 range
The answer is not as hard as it seems. I just tried for 10 minutes unsuccessfully to put the glass back in the two side tracks. Well the glass actually goes in front of them, the top holds the glass in place.
SOURCE: Took apart glass oven door on a whirlpool. Where
OVEN DOOR
Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
I have an older stove C970656912 that I took the door apart to clean and am having trouble putting all back together. Would love to see a manual but they ask to change the tool bar and I don't want to do this. Can anyone help?
