Question about Canon PowerShot SD1300 IS IXUS 105 Digital Camera
Camera kills battery
Have 2 canon sd1300 is cameras,can charge the batteries,but one camera will kill the battery just sitting,other camera will work fine,switched the batteries,same thing,camera will kill battery.Any help?
6ya staff
SOURCE:
Anonymous
SOURCE: Canon A95 gone dead
I ain't so lucky I'm in the UK too!!!! Generally speaking the cost pf packing, shipping repair, at any level is well on the way to the price of the next more recent higher specification device. Judging by the way the Megapixels go up by the week seemingly, settling for a replacement camera is usually the best option. I had a cheap[old] Fuji come my way because it had gone blurred and blue - sure sign of a CCD failure as this was at some time the subject of a recall for the problem I checked out Fuji Their response was to say no longer repaired but has a 1/3 off a new camera when I quoted a reference number. That seems to be the way to go.
Posted on Jul 30, 2007
Anonymous
SOURCE: canon powershot g5 - battery charge
Take out the battery and put it back and than recharge again. Some times in case of G5 it happens that the camera battery is not properly charged and the indicator shows that its fully charged (i.e. Green light) In such cases battery need to be taken out and than put back again and recharged
Regards,
Zain
Posted on Mar 20, 2008
Anonymous
SOURCE: Canon Ixus 75 not charging
The camera was working fine 2 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. Please help! bob
Posted on May 25, 2008
mcomijohns
Mike Johnson
  • 477 Answers
SOURCE: camera was working fine...all of a sudden,it would not turn on...thought maybe battery was dead,tried to recharge it,light would not go on,tried another charged battery,still would not work
This error is either a flash circuit or a lens error. One of the two need replacement.
Posted on May 25, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: Canon powershot SD1300 IS won't turn on, even
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Posted on Oct 11, 2011
Will not charge or turn on tried several methods still will not turn on got it used
If the camera has been sitting around I would suggest that the battery is dead and will not charge because its been not charged in a long time. Sitting without being charged will kill a battery.
Dec 22, 2016 | Cameras
I just recharged the battery on my Powershot SD1300 IS and now it will not turn on. any ideas would be appreciated.
Do you have another battery or set of batteries? The battery itself/batteries could be dead beyond repair. I always carry two sets of batteries. My Canon cam takes 4 AA.
May 21, 2015 | Canon PowerShot SD1300 IS Digital ELPH...
Canon 220ex does not power on
If you're sure the batteries are fresh, the polarity is observed when installing them, and the contacts are clean (use a clean pencil eraser and Q-Tip dipped in alcohol to clean) then you'll need to send the flash in for repair. Don't try to open and repair yourself. Flash capacitors can hold enough charge to kill you, even without batteries or seeming to work.
Jan 01, 2014 | Canon Cameras
Canon powershot SD1300 IS won't turn on, even with fully charged battery
Oct 11, 2011 | Canon PowerShot SD1300 IS IXUS 105...
My sister's camera says lens error . she's gonna kill me if it's broken !!!!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 30, 2011 | Canon PowerShot SD1300 IS IXUS 105...
I dont know what is going on with my camera, but i i charged the battery and now it wont turn on. i dont think i over charged the batt. because it wasnt on for that long. PLEASE RESPOND SOON i have a...
Rechargeable batteries can and do just die without warning.Sometimes the charger does so as well. The charger automatically prevents overcharging though.
Realistically, all you can do at short notice is to try another freshly charged NB-6L battery. if a camera shop has a display model they might allow you to try their battery in your camera, or more likely, your freshly charged battery in their camera.
Jul 22, 2011 | Canon PowerShot SD1300 IS IXUS 105...
It shut down
Try removing the battery and charging it in the charging cradle. If the camera does not turn on after you have charged the battery, it may be that the battery does not hold a charge (you can test this with a simple globe test light).
If this is the case, just go and buy a new battery and charge it fully before using.
Feb 22, 2011 | Canon PowerShot SD1300 IS IXUS 105...
I got this camera a few years ago for Christmas and unfortunatley it is the worst camera I've ever had as far as battery life. I can take 2 or 3 pictures and then it shows low battery. I've replaced new...
It seems there is some where inside the camera leakage.. Are you using Li-ion rechargeable batteries or AA batteries For previously cameras, always comes with AA batteries, and most of the battery are with low capacity.
Jan 08, 2011 | Canon PowerShot A540 Digital Camera
Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
37 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
