LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
Q - My electric dryer runs but will not heat, what could stop my dryer from heating? A - Things that could stop a electric dryer from heating: - house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug. A ohm meter test for these parts is here. Q - My gas dryer will not heat, what could stop my dryer from heating? A - Things that could stop a gas dryer from heating: - glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor. A page for checking gas dryers is here.
