Turning on the humidifier turns on the light. The pump does not spin. Inspection of the pump indicates it spins freely. The pump does not spin/move water.
SOURCE: motor turning real slow
THE MOTOR ONLY TURNS THE SPONGE DRUM AT MAYBE 10X'S PER MINUTE. THIS IS A BY-PASS TYPE HUMIDIFIER THAT RELIES ON YOU FURNACE BLOWER MOTOR TO SUPPLY AIR ACCROSS THE SPONGE MEDIA. NOTICE THE 5"-7" ROUND HOLE MUST BE DUCTED TO THE PLENUM OR RETURN AIR. (IF MOUNTED ON THE PLENUM, THE HOLE HAS TO BE DUCTED TO THE RETURN AIR, AND VISA-VERSA.) CAUTION!!!IF YOU HAVE CENTRAL AIR? A "DAMPER" MUST BE INSTALLED AND KEPT CLOSED THROUGH-OUT THE "COOLING SEASON". SERIOUS DAMAGE TO YOUR COMPRESSOR CAN RESULT FROM TOO COLD OF AIR ... CIRCULATING AND "BY-PASSING YOUR EVAPORATOR COIL".
SOURCE: the water refill icon keeps blinking, but the humidifier is full
have you checked the water sensor?
SOURCE: reset light on holmes product hls5000 humidifier
turn knob to reset....leave 15 minutes and then turn on
