Hi
Normally a fast freeze button is just that, it turns the compressor on permanently to freeze things down quickly.
I suspect that your run light is linked to the thermostat, and does not indicate that the freezer is turned off but that the temperature of the freezer is above the temperature set on the thermostat and the compressor is running to bring the temperature down. Once the temperature is at or below the thermostat temperature then the compressor will stop and the red light probably goes out, indicating the the freezer is at the right temperature.
It won't go out with the fast freeze on because to freeze food quickly the thermostat is by-passed and the compressor runs continuously.
Hope this helps.
This is normal if your freezer is in good working condition. If your compressor runs constantly then there is a problem. Once the unit reaches the set temperature the compressor shuts down. The set temperature should be between -2 & +2 degree F. The set temperature also depends on how full the freezer is. There will be a time when the freezer like refrigerators will shut down. This is relative to the term, "Frost Free". The unit will shut down for about 10 minutes. This occurs ever 8-10 hours. The heater turns on to defrost your freezer coil. It sounds like you are in good shape.
You need to replace the temperature control, (unless you find a bad wire connection to the temp control first). You can find a control that is close enough at any appliance parts store, bring the old one in for a match up. Make sure it is NOT a 39 degree constant cut in type and you will want a differential of at least 6 or 8 degrees minimum so that it wont "short cycle" which means it would run for a few minutes, shut off for a few then run again before the high side pressure comes down.
Leave it plugged in. It won't over freeze. If the outside air is cold then it won't need to run as much to bring down the temp-nature is doing that. So when the weather gets warm it will run to keep everything frozen. Hope this helps. Google burdfrenzy
It seem ambient temperature will not affect so much inside temperature since any freezer has good insulation.
Normally freezer will go down to below zero degree
your problem is likely the starting capacitor .. that is a metalic part (about the size of a fist) that is mounted on the compressor or near it .. it will have wires going to the compressor .. the capacitors are not very expensive and usually easy to change but make sure the unit is unplugged .. you can either write the numbers down off the capacitor or remove it and take it with you to a parts place to get a match ... take a photo or draw a diagram so you know where the wires go .(they usually just plug in) . .. you can order one from electrolux (might be higher price) .. dont allow the unit to continue running with the bad starting cap since the compressor can be damaged eventually ... if you call a repairman .. then make sure you tell him its a bad starting cap so he can bring one wiith him and avoild a second trip .. give him the model number and numbers off the capacitor if you can ... often the capacitor is actually two capacitors in one can ... one is for the compressor and the other is hooked up to the fan ... in that case replacing one would also replace the other ..
You have to defrost the coil by turnning of the unit and to make it faster leave the inside fan/s running.But if it's building up ice and the fan/s inside works ,is most probably that the unit is low in refrigerant(freon) , or the defrost system is not working.
First off it takes 24 hours for a freezer to bring the inside temperature down to a suitable temperature, but to replace the seal raise the edge of the seal and you will see the track that hold it on, please allow 24 hours to see if temperature drops and repost details
