2007 Yamaha MT-03 Logo
A
Anonymous Posted on Apr 07, 2014
How to install an ECU unit on a MT-03
A REPLACEMENT ECU UNIT
1helpful
2005 hyundai elantra gt 2.0l ECU replacement
I don't know for sure but I think the ECU will need programming with the vin-sensitive security code(s) and possibly other information that is exclusive to your car.
The so-called flashing is used to instal software patches and fixes in service when problems are encountered. Unless you are unlucky a new or official replacement ECU should already be loaded with the latest software version, but again the dealer should be your first port of call to ask such questions and then maybe compare notes and prices with a few local specialists..
I suggest you check with the dealer and ask if the part number has been superceded, or if the unit has been modified in the last ten years.
If there are no changes to the spec, the replacement ECU should have exactly the same part number as the original.
1helpful
Beeping Sound on my 03 VW Jetta
EPS is the electric power steering assist. That is different from the EPC light that is the traction control. Could be that the brake shop did not reset the system properly or they messed up a sensor.
4helpful
No spark , have changed the power tr unit , one plug sparks once
Given tha age of the car could very well be a bad ECU, Engine Control Unit. Early 90's mitsubishi's had poor capacitors in the ECU and tend to leak with time causing the ECU to fail. The ECU is located between the driver passenger seats behind radio. Remove two interior pieces from tunnel between seats and look for ECU (it has three large yellow plugs going to it) There should be (3) 10MM bolts holding it in place, remove and carefully open unit, pay special attention to area under capacitors. If you see a grease like product (often times it has green tone to it) unde any of the capacitors you most likely have found the problem. Reorder a rebuilt unit, when reordering be certain to refer to the MD number on the ECU cover for proper replacement.
I hope this may have assisted you,
Tom
Correct eec for 1989 ford f150 5.8l
Here is a listing of all possible computer modules for that truck. Perhaps this will help in some way in your search.
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL2B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-ALA
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-ALB
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN2B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-ANA
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-ANB
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP2B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-APA
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-APB
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), High Altitude
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AK1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AK2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E9TF-Z1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E9TF-Z2B
2003 vue ECU problems
make sure all grounds are connected. usually it is something easy or stupid.it should work.an obd-II scan may help pinpoint the problem.
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
