Hi Fred Tromp, you have two ways to connect the Technics SL PD7 CD player to the Technics SA-DX750
The first is through a fiber optic cable, from the Digital Optical output of the SL-PD7, to Optical Input 1 or Optical Input 2
The other alternative is to use a 2 RCA to 2 RCA cable and connect them between the L and R outputs of the SL-PD7 to the CD L and R inputs on the SA-DX750
I hope you can interconnect the equipment
Regards Franco Dosil
Hola Fred Tromp, tienes dos maneras de conectar el reproductor de CD Technics SL PD7 al Technics SA-DX750
La primera es a traves de un cable de fibra optica, desde la salida Digital Optica del SL-PD7, hasta la Entrada Optica 1 ? Entrada Optica 2
La otra alternativa es usar un cable de 2 RCA a 2 RCA y conectarlos entre las salidas L y R del SL-PD7 a las entradas L y R de CD en el SA-DX750
Espero puedas interconectar los equipos
Saludos Franco Dosil
http://www.usersmanualguide.com/panasonic/compact_disc_changer/sl-pd7
https://www.manualslib.com/manual/169257/Technics-Sa-Dx750.html
The problem is that the Technics AV Control Receiver SA-DX750 does not have the auxilliary input or the auxilliary option in the selector. Can I connect the ipod to some of the other inputs?
There are inputs for CD, TAPE TV, VCR and DVD. There is also an input for digital equipment, a hole for a coaxial, basically.
