Fargo Persona  C30 Thermal Card Printer Logo
A
Anonymous Posted on Apr 07, 2014
C30 fargo vista 64 - Fargo Persona C30 Thermal Card Printer
5 Related Answers
Anonymous
  • 526 Answers
  • Posted on Apr 23, 2009
SOURCE: software update for persona c30
You need to be a little more precise on your question, I am not sure if you are asking for new drivers for the c30 or firmware? or you have it already and dont know what to do. I'll assume its the first.
go to www.fargo.com to download the latest printer drivers for your C30. Also the firmware is up to 4.6.3 i believe.
thank you
Anonymous
  • 526 Answers
  • Posted on Dec 17, 2009
SOURCE: Broken ribbon on the Fargo Persona C30
Try a sensor calibration, its done through the printer drivers.
Anonymous
  • 14 Answers
  • Posted on Jan 12, 2010
SOURCE: fARGO c30 Won't print, gives following error
You have not mentioned the application you are using.
This is probably not a problem with the printer. this is mostly possible due to macros in the application through which you are printing the cards
try to find out if any patches available for your application.
Also try to install your application again after doing uninstall of the same.
Hope this will definitely solve your problem. Do remeber to run microsoft update for your operating system
Anonymous
  • 526 Answers
  • Posted on Aug 12, 2010
SOURCE: Why is it my Fargo C30 printer cant work with
currently there are no drivers available on fargos website for the drivers.
you can try the older version, but no guarantee it will work.
the new fargo printers coming out will support windows 7.
Anonymous
  • Posted on Dec 02, 2010
SOURCE: Is there a 64 bit Fargo C30 driver for Windows 7?
Hello Madeline,
my distributor says there are no Windows 7 drivers for Persona c30. They do not have drivers for the successor c30e for win 7.
Why my persona c30 fargo breaks all ribbons installs Thanks
Mind the printing ofset settings, colour intensity as well!
4helpful
Hello Madeline,
Solving Card Jam problem with FARGO PERSONA C30 ID CARD Printer.
Hey I hope you can help me, My c30 persona printer is task, theres a badge inside and cant get out, what can I do?
Why is it my Fargo C30 printer cant work with Windows 7
I only printed meybe a dozen cards from my Fargo C30 printer. When I install the driver, the XP and Vista computers will not find the printer via USB. Is there a special type of USB cable? Is there a way...
Try using the cable as provided along with your printer.
try to download the driver for XP and Vista from manufacturer website from this link
http://www.fargosupport.com/search_results.asp?pulldowntype=&all=1&printer=73&submit.x=24&submit.y=7
download the driver for windows XP
work bench utility
If your problem is not solved then replace the cable with another similar and connecting the printer to a different usb port on your computer.
try installing in a different computer
28helpful
2answers
Need driver for persona c30 for windows 7
Every required driver can be downloaded from this tool: Driver Update Software.
Hope this helped
Donald
What kind of power cord should i use for Fargo Persona c30 printer
For your fargo persona C30 you need a power adopter of folowing rating description:
input: 100-240V -2A, 50-60Hz AC
output: 24V/2.5A, 60Watt max DC
3answers
Fargo P C30
you probably have a scratch on the printhead.
Software update for persona c30 card printer by fargo
thank you
Top Fargo Office Equipment & Supplies Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
