KitchenAid KHMS155L Microwave Oven Logo
A
Anonymous Posted on Apr 07, 2014
Loud humming noise mod#khms155lss0 - KitchenAid KHMS155L Microwave Oven
A sound like hooter comes after few second during microwave cooking. what is the problem.
If your microwave is making an unusual or loud humming noise, you may have a problem with the magnetron. This component is part of the high voltage circuit and provides the microwaves that generate the heat. If the magnetron is defective, it may cause a loud humming or buzzing noise
Microwave is making a noise
If your microwave is making an unusual or loud humming noise, you may have a problem with the magnetron. This component is part of the high voltage circuit and provides the microwaves that generate the heat. If the magnetron is defective, it may cause a loud humming or buzzing noise.
https://www.fix.com/repair/appliance/microwave/unusual-noise/
My Kitchenaid combo convection/mw works on convect but has a loud humming and no heat on microwave.
A loud humming noise in microwave mode will usually be a shorted high voltage diode or bad magnetron.
My new GE over the range microwave works fine but has a loud buzzing/humming noise when in use
This sound you describe is not normal and should be checked quickly, even if it means returning the item.
My microwave makes a loud humming noise when it is turned on.
May as well use the microwave as is until it terminates naturally. All microwave ovens buzz, that nothing unusual, but although you can replace a Magnetron, the cost is unusually high. By the time you take the oven down, open the case and fuss around, perhaps not making things any better; the fact is; a new replacement with a warranty is just over $100. Why bother?
3helpful
GE Microwave making loud humming noise
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
Dave
1helpful
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
2helpful
Loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
Loud humming noise when in use
We had this problem with a new GE microwave in our last home. GE service replaced fan assy,.AND added rubber foam around the motor, Loud hum was reduced,but never did completely go away. We learned to live with it/
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
