Motorola Mobility H710 Bluetooth Headset Logo
A
Anonymous Posted on Apr 07, 2014
Blue light will not show on h710 - Motorola Mobility H710 Bluetooth Headset
Motorola H710 Bluetooth Headset will not turn on!
I have the exact same problem with my Motorola H710 Bluetooth Headset. When I charge the headset a green light is displayed. After the charge is complete I unplug the headset and NO light is displayed. I flip open the boom and NO light is displayed. I hold the call button for 10 secs or 10 mins or 10 hours and NO light is displayed. There is suppose to be a blue light displayed to indicate that the headset is ON. Since there is NO light displaying that means the headset is OFF. So my headset DOES NOT TURN ON! I did my research no where online can anyone give a solution. All the above solutions given does not help because the blue light DOES NOT turn on. No user guide or customer service rep or tech support can help that is what I found out. So I guess I will toss my headset in the garbage!
3helpful
How to connect my motorola H710 bluetooth with my mobile
You must put it in pairing mode. If it has not been paired to other phones, just open its boom. After a while the indicator LED will be steady blue. Otherwise, if it has been previously paired to other devices, make sure the bluetooth radio of those devices are turned off. Then, open the boom and, as the headset won't find any devices already paired around, it will enter pairing mode automatically (again, indicated by the steady blue LED).
Once your headset is in pairing mode, make your phone's bluetooth application search for new devices. After a while, the H710 will show on screen. Select it and command it to proceed. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
By the way, if your headset's user guide happens to be missing, you can download it from this location;
Hope you are able to sort your problems out.
Cheers! Carlos
9helpful
I can't get my H710 to go into pairing mode... solid blue
First, if you've already paired it with another phone, make sure that phone is turned off. Close the headset and wait a few seconds, then reopen it by flipping out the boom (mouthpiece).
If that doesn't work, try this adapted method from the H700 model: Press the multi-function (center) button and hold it in until the light turns blue. As soon as you see the blue light, immediately open the boom (mouthpiece). Hopefully it will remain solid blue, indicating you're in pairing mode.
3helpful
Need instructions on how to pair bluetooth motorola H710 with blackberry curve
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
2helpful
2answers
How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
1helpful
H710 won't go into pairing mode
sounds like its already connected to the iphone but it won't establish them. Delete the pairing from the phone then repeat the process.
4helpful
2answers
Have motorola h710 bluetooth headset and no instruction manual so i dont know how to pair it up
it is universal procedure to pair up all devices like this
first if ur hedset is switched on switch it OFF by long pressing the main button in the centre it will blink blue light twice or thrice and will switch OFF after that u can touch any button it will not respond with blinking lights
Now press again that centre main button long press for like 10 sec until that blue light comes on and become STABLE when it is stable it means it is ready to pair up with any bluetooth phone now go to ur phone switch the bluetooth ON and select search u will find ur headset with its model like H710 just select and when asked for pairing code enter 0000 Zero four times , now u will see that ur headset light will start blinking and u will see a headset sign on the screen of ur mobile phone it means now it is paired up
now u can try to talk thru headset make a test call any number for voulume control there are two buttons on headset on upper sie with arrows u can select them to increase headset sound
pls rate me well for help ! Fixya rating is encouraging !
2helpful
Lost my instuctions...
first if ur headset is switched on switch it OFF by long pressing the main button in the centre it will blink blue light twice or thrice and will switch OFF after that u can touch any button it will not respond with blinking lights
Now press again that centre main button long press for like 10 sec until that blue light comes on and become STABLE when it is stable it means it is ready to pair up with any bluetooth device now go to ur PS sony switch the bluetooth ON and select search u will find ur headset with its model like H710 just select and when asked for pairing code enter 0000 Zero four times or try 8888 if it doesnt work , now u will see that ur headset light will start blinking and u will see a headset sign on the screen of ur mobile phone it means now it is paired up
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
