SOURCE: Microwave with load buzz and not heating.
With the symptoms you
have, I would most strongly suspect a shorted high voltage rectifier
diode or a bad magnetron.
It may be a problem with the transformer, but I suspect that less.
The diode is a fairly
cheap fix, and the mag will cost more. The transformer may be pretty steep. But it's best to take it a step at a time.
If you or someone you
know
decide to look into it, we have critical safety information and
disassembly information at our site, and our link is at our listing here on FixYa.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted, it's
probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
